Ansys Fluent doesn't work
Hello everyone,
I recently downloaded the student version of Ansys to perform a flow simulation. After downloading everything works well, except the Fluent application. I can open it thru workbench, but then it's loading all the time, and after a while it's giving the following error:
When I go true the recently added programs, new ansys programs are added, but Fluent isn't present in that list.
I already did research on this forum and tried some things that worked with other members, but without success.
The following steps I already undertook:
1. I tried to run the launcher of the Fluent application. Then this error occurred:
It is saying that the system can't find the following files:
libansysfluidscffinterface.dll
Qt5Widgets.dll
libansysfluidsfactory.dll
Qt5Gui.dll
2. after that I re-installed Ansys but this also didn't help.
3. Then I deleted all the Ansys files, shut down the firewall and virus scanner, changed the language to english, and downloaded the files again. After that exactly the same errors occurred again.
I hope someone can help me out with this.
Kind regards,
Jesse van Asseldonk
I found a solution for my problem. For the people how has the same problem as discribed above, I would prefer to read the following discussion:
