ANSYS Workbench has stopped working — Ansys Learning Forum
didsdids Member Posts: 10
When I am starting Ansys, I get this message:
How can I fix it?
  • mmadoremmadore Ansys Employee Posts: 823
    @dids Was this previously working? Please try renaming your %APPDATA%\Ansys directory to %APPDATA%\Ansys.old.
  • didsdids Member Posts: 10
    @mmadore
    No it never worked. Where is %APPDATA%\Ansys, i don't find it
    @mmadore
    Please share the full text of your C:\Program Files\Ansys Inc\install.log and install.err files.
    @mmadore
    Start Installation: Paz Mar 21 20:49:08 2021
    Revision: 2021 R1
    Platform specifics:
      Windows
    Username of Installer: Apple-PC\Apple
    User Has Administrator Privileges
    C:\Users\Apple\AppData\Local\Temp\ans_install_tmp2404\instcore.exe -usetempdir C:\Users\Apple\AppData\Local\Temp\ans_install_tmp2404 -launchdir C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510 -admin
    Initial mount directory:
    Installation Directory:
      C:\Users\Apple\Desktop\ANSYS Inc\ANSYS Student
    Windows x64
         EnSight
    Date verification complete...No conflicts found.
    The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
    This may take a while ...
    Successfully copied prerequisites from media.
    You don't need to install any prerequisites.
    Reading the installation media contents - please wait.
     Extraction: C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510\framewrk\WINX64.7z ...
     Extraction: C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510\instcore\tcl\COMMON.TGZ ...
     Extraction: C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510\instcore\tcl\WINX64.TGZ ...
    This looks like your install didn't go properly. Please download the product again and extract the .zip file. Once extracted you need to right-click on setup.exe within the extracted files and "Run as administrator". You should see something similar to this in the install log:
      C:\Users\Apple\Downloads\ANSYSACADEMICSTUDENT_2021R1_WINX64
      C:\Program Files\ANSYS Inc\ANSYS Student
    @mmadore I have both but i don't understand why it makes mistakes
    @dids Your file indicates
    This would indicate that you are not installing from the extracted files, but instead directly from the zip or temp files. You must extract the zip and run the setup from the extracted files. The install.log and install.err should be in C:\Program Files\Ansys Inc\Ansys Student\
    @mmadore I installed again but i didn't see C:\Program Files\Ansys Inc\Ansys Student\ this file
    That's not the C:\Program Files\Ansys Inc\Ansys Student. That would look like this:
    I understand but i don't have this file
    It may not be C:\Program Files, but wherever you installed it there would be an "Ansys Inc\Ansys Student".
    I found what i have to do now @mmadore
    My problem is fluid flow (fluent) mesh part. I finished geometry part then i want to edit mesh part but it give error @mmadore
    Did you find the %APPDATA% directory to delete the Ansys files? It is typically C:\Users\Username\AppData\Roaming. Please try renaming Ansys to Ansys.old. Please share the error messages if they persist.
