Can't find "LS-Dyna Export" Component
myvuemyvue Member Posts: 6
Hello everyone,
In the ANSYS Workbench (2020 R1), I cannot find the component that exports the .k file from ANSYS to LS-Dyna (Explicit Dynamics, LS-Dyna Export). I also checked the install log file and it shows me that I installed it. Could you please help? Thank you.
  • myvuemyvue Posts: 17Member
    I uninstalled, and then reinstalled ANSYS, but the problem still persists.
  • gnagappgnagapp Posts: 99Forum Coordinator
    @myvue
    Go to Tools -> Options -> Appearance and turn on “Beta options” and also turn on “Unsupported Features”
    The LS-Dyna Export does require a Ansys LS-Dyna license
    If it still doesn't show up
    Click on View all/customize at the bottom of the toolbox
    Then turn on the LS Dyna Export system
    LS PrePost can read in Nastran files. So, you can write out a Nastran file from Mechanical application. Being sure to set mesh pref to explicit. Then read it into LSPP and translate to k file.
  • ramgopisettiramgopisetti Posts: 102Member
    Hi @myvue , you can export k file by clicking write input file and you can choose .k and .key or you can look in the solve directory of your simulation and check for .k file and make sure you are on current system
    cheers Ram
