Will the density of materials in the Maxwell 3D material library change with the set weight?
I created a 3D model of aluminum material. If I do not change the volume of the model, but only change the weight of the model in the model, will the system automatically adjust the density of the model? Or is the default aluminum density unchanged?
nchode Posts: 224Forum Coordinator
Hi @whyty123,
Where are you changing the weight of the model?
The mass of your 3D model is driven by assigning material from the material library within the Maxwell. You can edit the material properties like mass density in the material library of Maxwell. Maxwell will not consider any mass properties defined in your CAD tool.
Navya
