Time domain scripting for dipole source — Ansys Learning Forum
MANNANMANNAN Member Posts: 9
I would like to manually script the properties of a dipole source in FDTD so that the waveform of dipole looks as shown above. I need help how to script my dipole properties in the time domain as shown in the example below
How can I manually script in the dipole source code to add the following parameters in set time-domain data like pulse-type (broadband), frequency, pulse length, offset, and bandwidth?
looking forward to a fruitful discussion.
Regards
Mannan
  • gsungsun Ansys Employee Posts: 227
    you can use set("set time domain",1); to enable a tab property. One this is enabled, you can set other properties, as you did in the script, such as
    set("offset",3e-12);
    please note that the units in scripting are international standard, meter, second, kg etc.
    you can use
    ?set; when an object is selected to know all its parameters
    or
    ?setnamed("object_name") to know the parameters for a specific object.
    Please try and check if all the set results are what you expect.
    Please note that since the source is a pulse, even through you set the wavelength bandwidth zero, it will still be a pulse, meaning it will radiate em waves in a broadband.
  • MANNANMANNAN Member Posts: 9
    Thanks a lot it worked
    Thank you for letting me know this! good luck in your project!
    Could you please further help in regarding the this
    x=linspace(-d/2,d/2,N); # x position vector
    for (i=1:N) {
    adddipole;
    set("x",x(i));
    set("y",0);
    set("z",0);
    This code will make a line of N dipoles along the x-axis between length -d till d. with equal spacing
    Suggestions required in making a script that will make a cone of dipole along xz direction with radius r in x-direction and depth along z-axis
    Looking forward to hearing soo
    The code looks good for me. In order to make the dipoles to be in a cone in xz plane, you will need to change x(i) and z(i) as a cone, and then place the dipoles there. Please try to modify your script.
