Commands skipped when solution does not converge.
bouzasoscarbouzasoscar Member Posts: 8
edited March 23 in Structures
I am developing a nonlinear probabilistic structural analysis using Mechanical. In this analysis some of the nonlinear iterations will fail, so they do not converge.
Here is the problem. I have some Commands (APDL) after the solution that they need to be run for each iteration, but when the solution does not converge they don't run, they are skipped.
Is there a way to force ANSYS to always run those Commands despite the convergence of the solution?
Thanks in advance.
