Workbench Ls-Dyna Eroding Contact
Hi There,
Recently working on eroding contact in Workbench Ls-Dyna. The question is how to define eroding contact in WB Ls-Dyna. There is not default menu under analysis settings just like WB Autodyn. I tried to add from Ls-Dyna Pre menu Contact Property then selected body interaction define eroding. But it did not work. It passed to other side of the panel but panel does not erode. I also changed a few things on details of contact properties in Advanced control card according to instructions but i could not erode panel. Where is the problem.
Hi aozer,
You will need Keyword Snippets to replace the existing contact logic with eroding contact logic. This is not included in workbench ls-dyna GUI.
Hi Kai,
Thank you your comments. What kinds of snippets? Do I need to enter them with comment prompt? Could you give some example?
