Troubleshooting RSM problems (for Intel MPI) — Ansys Learning Forum
apr37apr37 Member Posts: 30
I have ANSYS EDT 2021 R1 installed on a few computers, along with RSM service and the Intel MPI. Last week I was able to successfully analyze a simulation using multiple machines in a HPC configuration, but this week some of the compute node machines are not cooperating. While running an analysis, message manager tells me
[error] Unable to locate or start COM engine on '[compute node]' : Unable to reach AnsoftRSMService.
And when I go to 'Test Machines' in the analysis configuration, the problem machines say ANS_CANNOT_CONNECTTO_ANSOFTRSMSERVICE
I check for proper MPI behavior on the compute nodes using the following commands in command prompt:
C:\Windows\system32>hydra_service -status
Response: hydra service running on [compute node]
and
mpiexec -validate
Response: SUCCESS
Firewalls on all machines have been turned off.
What troubleshooting steps can I take from here to try and narrow down the problem? I remember when I used to use the IBM MPI, I could use the following command to check for MPI function between two machines:
"%MPI_ROOT%\bin\mpirun" -hostlist localhost:2,[compute node DNS name]:2 "%ANSYSEM_ROOT201%\schedulers\diagnostics\Utils\pcmpi_test.exe"
Is there a similar command for use with the Intel MPI?
Any other suggestions are also appreciated.
Thank you!
-Alex
  • mmadoremmadore Ansys Employee Posts: 823
    Accepted Answer
    @apr37 Please make sure you have installed Ansoft RSM on all machines and registered the engines.
    http://storage.ansys.com/doclinks/videos.html?code=InsElecRSMonWindows-VLU-K0a
    To test Intel MPI:
    Try this - first with existing computer and then add the new one - you can add/remove by adding from ': -n 2 computername "C:\Program Files\AnsysEM\AnsysEM21.1\Win64\schedulers\diagnostics\Utils\intelmpi_test.exe"' onward for each computer.
    "C:\Program Files\AnsysEM\AnsysEM21.1\Win64\common\fluent_mpi\multiport\mpi\win64\intel\bin\mpiexec" -n 2 -host computer1 "C:\Program Files\AnsysEM\AnsysEM21.1\Win64\schedulers\diagnostics\Utils\intelmpi_test.exe" : -n 2 -host computer2 "C:\Program Files\AnsysEM\AnsysEM21.1\Win64\schedulers\diagnostics\Utils\intelmpi_test.exe"
    Output should be something like:
    Intel MPI
    Hello world! I'm rank 0 of 4 running on computer1
    Hello world! I'm rank 1 of 4 running on computer1
    Hello world! I'm rank 2 of 4 running on computer2
    Hello world! I'm rank 3 of 4 running on computer2
    Thank you,
    Matt
    Accepted Answer
    To test Intel MPI:
    Intel MPI
    Thank you,
    Matt
  • apr37apr37 Member Posts: 30
    Alright! Looks like even though I had installed and registered RSM on all the computers, somewhere along the line something happened that required me to do it again. At first I attempted to go straight to registering with RSM and on the affected computers several errors were returned along the lines of
    "C:/Program Fiels/AnsysEM/AnsusEM21.1/Win64/RXPRTCOMENGINE.exe: Error obtaining status
    > Please make sure that Remote Simulation Manager is installed and running"
    I did a repair installation of RSM, re-registered successfully, and now I am once again able to do distributed solves with those machines.
    Also, your suggested Intel MPI test command worked as expected for me. Thanks for that, too.
