Installation problem
I installed the student version of Ansys, but the software does not work, and there is a problem like below,
Can you help me?
Microsoft (R) Windows Debugger Version 10.0.21306.1007 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\LENOVO\AppData\Local\Temp\AnsysWBDumpFile.dmp] User Mini Dump File: Only registers, stack and portions of memory are available Symbol search path is: srv* Executable search path is: Windows 10 Version 18363 MP (8 procs) Free x64 Product: WinNt, suite: SingleUserTS Personal Edition build lab: 18362.1.amd64fre.19h1_release.190318-1202 Machine Name: Debug session time: Tue Mar 23 20:26:08.000 2021 (UTC + 3:00) System Uptime: not available Process Uptime: 0 days 0:00:09.000 ................................................................ ................................................................ ................................................................ ................................................................ ....................... This dump file has an exception of interest stored in it. The stored exception information can be accessed via .ecxr. (1e8c.4430): Access violation - code c0000005 (first/second chance not available) For analysis of this file, run !analyze -v ntdll!NtGetContextThread+0x14: 00007ffd`c417eb24 c3 ret 0:000> !analyze -v
@grkn Could you please open a Windows command prompt and run the command "set" without quotes and send the full output?
