issue with maxwell machine toolkit extension for switched reluctance motors
forsyth307forsyth307 Member Posts: 1
Has anyone gotten this to work for a switched reluctance motor since its release?
I'm using 2021 R1 and every time I try to run the machine toolkit for an SRM it uses an auto generated external circuit to define the motor current. The problem is that it sets the current to zero for iteration, regardless of what I put as the current parameter, and thus creates an efficiency map using zero current. The external circuit is inaccessible.
