Not enough HPC Parallel licenses 20/0.
I have a few Windows 10 machines with Ansys EDT, RSM and Intel MPI installed, configured together in a HPC setup for doing distributed solves. I am able to execute and complete analysis of the simulation, but when I start a solve, my Message Manager always opens with the following:
[error] Not enough HPC Parallel licenses 20/0. (10:31:59 AM Mar 23, 2021)
[error] Simulation was terminated by license error. (10:31:59 AM Mar 23, 2021)
[error] Not enough HPC Parallel licenses 20/0. (10:32:02 AM Mar 23, 2021)
[error] Simulation was terminated by license error. (10:32:02 AM Mar 23, 2021)
[error] Not enough HPC Parallel licenses 20/0. (10:32:04 AM Mar 23, 2021)
[error] Simulation was terminated by license error. (10:32:04 AM Mar 23, 2021)
[info] Parametric Analysis on 1_test_sweep_centered has been started. (10:32:05 AM Mar 23, 2021)
[info] A variation (sample_position='0.001mm') has been requested using the following machines: localhost. (10:32:07 AM Mar 23, 2021)
It seems to be repeating itself once per remote machine I have set up as a compute node before a request is made by localhost like normal. Performance doesn't seem to be affected (remote compute nodes still request and solve variations), and this happens even when I have firewalls turned off on all machines.
What does this mean? What could be causing this to happen? How should I go about fixing it?
Thank you,
Alex
@apr37 Can you share what you have set for your HPC and Analysis Options tabs and analysis configuration setting?
Here is my HPC and Analysis Options
Is this what you are looking for?
@apr37 Please change "Use legacy Electronics HPC License" to True.
Should I change that setting on the head node and compute nodes, or just the head node only?
When I change it on all nodes (testing with only two computers for now), Progress hangs on
"Determing memory availability on distributed machines on Local Machine."
And I need to abort the process.
When I change it on only the head node, I get an execution error in message manager:
[error] Could not start the memory inquiry solver: check distributed installations, MPI availability, MPI authentication and firewall settings. (8:16:24 AM Mar 26, 2021)
[error] Simulation completed with execution error on server: Local Machine. (8:16:44 AM Mar 26, 2021)
I have made no changes to the firewall since I last successfully distributed a solve with the old license settings shown the earlier screenshot.
model checkup is done without checking a license. there are many license types, so you should inquire the distributor about which you have, or try every option mentioned above.
but sometimes the license server just does not work or freeze licenses. it is a big problem existing from the beginning of flexlm. it is simply not reliable in big networks.
so check the debug logs at the server, and see, did your client really tried borrowing a license? if yes, what was the real reason of failure? if not, check IP packets passing, firewalls, router etc.
Thanks for the information, AndyJP.
I'm fairly naive to the inner workings of the system, but I am eager to learn and get a better grasp of how to diagnose and fix problems like this and generally understand the system better. I have a few questions for you:
Thanks again,
Alex
@apr37 The messages have nothing to do with licensing.
If you are submitting the job interactively from the local AEDT, with the project open and specifying the hosts under HPC and Analysis Options -> Configurations, you only need to set it on the machine submitting the job. If you are using the "Submit Job" UI you would want to set it in the Batch Options.
Based on your previous post have you tried disabling the firewall to see if that will allow the job to run? If that works, you will need to open the firewall further as per the previous post. Typically the errors you are seeing are related to the MPI processes failing to communicate due to a firewall.
The reason the job previously ran is because the Parametric Analysis isn't running with MPI though it does distribute.
