How to model Carbon Nano Tube in Concrete using the RVE in Material Designer? — Ansys Learning Forum
samta0603samta0603 Member Posts: 2
I have modelled the CNT and Concrete using Random UD in Material Designer. But I am not sure if this is correct, it is working for a specific fiber volume fraction and for higher fiber volume fraction it is not meshing the model. Please guide me with some Steps, finally I want to do the compression test for the sample.
  • ramgopisettiramgopisetti Member Posts: 102
    Accepted Answer
    Hi @samta0603 , it will mesh as long as you are not too aggressive with percentage of cnt and mesh size , however, based on system you use it might take time to compute and update mesh.that said, These are my initial guess , if you could able to post the image with proxy percentages you could get better support here
    cheers, Ram
    Accepted Answer
    cheers, Ram
  • samta0603samta0603 Member Posts: 2
    edited March 28
    Thank you @ramgopisetti . I have kept the percentage really less starting from 0.15% of cement. I have generated the results also, I used UD Random Composite, it gave the results, but to study the effect of orientation I wanted to model in Chopped Fiber Composite, but there it is showing some memory issue. I have a 8GB Ram laptop, it says it needs 4GB, but still it is not working.
    It is asking to increase the virtual memory, I tried that also. But still it is having memory problem.
    Also I performed the compression on the cuboid of size 150mm, as I increase the % of CNT the total deformation and equivalent stress is decreasing but the normal stress is increasing, what can be the mistake?
