Can i get help on a step by step to run a pull out simulation for screw in a block?
Currently attempted to place supports around block in different areas. Attempted a explicit dynamics version it failed as well. Could you please aid with a step by step to set up this test and how the assembly of the two components should be set up.
I can attached the files.
scenarios and all failed to provide results
