Manifest Error / Critical Error:
Hi 😊😊👋 👋 Can anybody give me some guidance ? I reinstalled almost 10 times .. but st.ill get the same error msg stating uninstall.dat file not found.
@AnsysFreak Please make sure you extract the downloaded .zip file and run the setup.exe from the extracted files. Typically this error occurs if installing directly from the .zip file.
Yes sir. I extracted the zip file which I downloaded from Google Chrome. By right click " Extract all " to c:\temp folder .. next I right click to run as administrator .. the installation directory should be c:\program files ? Or other installation directory?
This file is 0KB .. I'm getting .err files whenever it's done installing.. but I can't click next .. there's only 1 button exit left.
I tried several solution from other post but still no avail.
. hELP !!😭😭😭😭😭👋👋👋🐿️🐿️
@AnsysFreak Once it completes installation and you click "Next" it has the install.err file. Please share the full contents of that file.
