Tangent Modulus (ls-dyna) — Ansys Learning Forum
goktug.yilmazgoktug.yilmaz Member Posts: 14
edited March 26 in Materials
Hi everyone!
I want to obtain tangent modulus from the results of my uniaxial tensile test. I find the picture below on the internet. However, as you can see, there are infinite number of points where you can calculate the slope. To obtain the tangent modulus of my material, which point's slope is required?
In brief, how can I calculate the etan (tangent modulus) value from my diagram?
  • ramgopisettiramgopisetti Member Posts: 102
    Accepted Answer
     E_tan_Calculated / E ratio may be closer to an Elastic-perfectly
    plastic case.
    E_tan_Calculated = [(1+%EL/100)*S_ult - S_yield ]/ [(ln(1/(1-%RA/100)))- (S_yield/E)]
    %EL= % Elongation
    %RA= % Reduction in Area
    E = Modulus
    The strengths are self Explanatory.
    If you don't know the %RA you can approximate by
    %RA =200*%EL/(100+2*%EL)
    Check your other post for detailed answer.
    Cheers, Ram
    Accepted Answer
    plastic case.
    %EL= % Elongation
    E = Modulus
    Cheers, Ram
  • goktug.yilmazgoktug.yilmaz Member Posts: 14
    edited April 5
    Dear sir,
    Thank you very much for your help. I am very grateful to you.
    Could you please recommend a source to me where I can also see those formulations?
