Error compilation failed for load curve(FUNCTION ) in mat 106 sph
jhon9jhon9 Member Posts: 3
Hello i try to use mat 106 in sph simulation by Lsdyna. im use DEFINE_CURVE_FUNCTION for temperature dependent data like below
POLY(TEMP, 0, 5.31e+07,-3.521e+06, 7332,-3.333)
but get this error:
Beginning of keyword reader
   *** Error compilation failed for load curve 3
 *** Error 10907 (KEY+907)
        Incorrect type of argument for function
   *** Error compilation failed for load curve 4
   *** Error compilation failed for load curve 5
   *** Error compilation failed for load curve 6
   *** Error compilation failed for load curve 7
   *** Error compilation failed for load curve 8
 Memory required to process keyword   :   1725526
 *** Error 20122 (STR+122)
   part id 3 uses a thermal material type
   but no thermal option is active.
how to fix this problem?
best regards
  • jdayjday Posts: 8Member
    I suspect the function TEMP ...
    (a) is only meaningful when the analysis is a thermal-only or coupled thermal/mechanical analysis, and
    (b) requires a node number as an argument, e.g., TEMP(100) would be the temperature at node ID 100.
  • jhon9jhon9 Posts: 6Member
    thank you. how to write curve as a funection of temperature in every node? i want deffine temperature dependent material.
