Simulating an array of pillars following an Archimedes spiral path/ Lumerical FDTD
wchayeb18wchayeb18 Member Posts: 1
I am trying to create an array of two rotated rectangles, a column with angle 1 rotated rectangles and the other with angle2
angle1 and 2 are with respect to the +y axis
my problem is that i want to write a script such that the two columns follow an archimedes spiral path.
The equation of the archimedes spiral in cylindrical coordinates is given by the following:
The columns are etched on a layer of gold placed on top of Glass, I want to see the response
of this structure with respect to Right and left circular polarized light.
I would appreciate any help regarding writing a script of the sprial path.
Many thanks
  • gsungsun Posts: 1,152Ansys Employee
    This is an interesting device. As you know, objects need a center location (x,y,z). as long as you can give the correct locations of the objects at different angles, you will be able to place them correctly. For a simple test, please just use one rectangle, same size, same rotation angle, and try to set it into the spiral curve. Once it works, I believe you will know how does it work, and can apply this to the actual component with more rectangles.
