AnsysWBU.exe encountered a problem/Ansys 2020R2 getting crashed
Hi all,
In the Ansys 2020R2 mechanical window , Every time i click for example Mesh or some results i get this message " AnsysWBU.exe encountered a problem". Its getting crashed and when i click OK mechanical window getting closed.
Here is the error from Event logger:
Exception code: 0xc000041d
Fault offset: 0x000000000003c321
Faulting process id: 0x22b60
Faulting application start time: 0x01d72263dc2f9a1b
Faulting application path: C:\Program Files\ANSYS Inc\v202\aisol\bin\winx64\AnsysWBU.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 1297748f-c4e5-48c0-9b3b-372bedb6c7f2
Faulting package full name:
Faulting package-relative application ID:
I have installed all the ansys prerequisites, deleted temp files, renamed in %appdata% directory. The other older ansys versions work fine on that machine, only issue with 2020R2. Kindly help me with a to fix this issue.
