Parametric Analysis
I created below geometry from Rmxpert. Now I would like to sweep parameter like DiaGap, hs2. In parametric setup I am not able to add these variables. Please help
Please let me know how to do that.
Hi @Bobby11,
You need to define a variable against the Name for which you want to run a parametric analysis.
For example:- To parameterize DiaGap (in your screenshot) instead of giving a value(120) to it you can write a variable like "DG" or anything you want.
Then a popup window will show you to add the variable nominal parameters. Now you can go to parametric and you will find the variable DG in the dropdown list.
Refer to "Working with variables" section in the Maxwell help document
Navya
