s21 increasing problem
in Electronics
i just simulated taper waveguide.
But i have a problem because at certain frequency, s21 increased to about 3db.
Is it possible?
I don't know why this is happening.
Is it a setting error or a simulation error on hfss?
insufficient mesh density. add more passes and reduce convergence DeltaS. Set the solution frequensy, or add another setup frequency just above the resonance
Hi @park0415,
It looks like the simulation setting error. Please check your design thoroughly and try simulating it again.
All the very best.
