Error loading container engineering data 1: An item with the same key has already been added.
in Materials
I have a thermal simulation using composite material from the material designer. When I try to open mechanical I get the error stated in the summary above.
It could be possible that project is corrupted, you can try to recover it using method explained at:
If that does not work, you may have to rebuild the project.
-Aniket
