This might happen if the structure is unconstrained or if any contacts are open. Please insert a contact tool to check the status of each contact. You might run a modal analysis with frictional contact suppressed to see if model is adequately constrained.
All Lumerical installation and licensing questions should be posted in the Ansys Products Installation category.
Hello @ahlamosama,
Ishan.
