Downloading question
I downloaded the academic free student software. I get an error when I click on the setup.exe file. Could you please help me with this issue to correct it?
Thank you
Shahram Fotowat
15199913424
Thank you
Shahram Fotowat
15199913424
Have you extracted the zip or did you try and run from the archive? The former tends to work, the latter generally fails. We also need more information, "an error" means digging out the crystal ball: all my tea leaves are telling me is that my mug is empty.
@fotowat,
First, do not extract into: c:\program files\Ansys Inc
Extract into a temporary director say, like: c:\temp\Download
When extracted, right click on setup.exe and choose run as administrator.
Most of the time, the "not responding error" can be due to a Virus scanner, try shutting down the virus scanner.
One other item I see is that you are low on disk space for c:\...just and FYI, I dont believe this to have any cause to the issue at hand, however
you may want to clean up some disk space.
Also, if you search on critical error not responding you should see some other threads.
Like: Rename %APPDATA%\Ansys to Ansys.old then retry installation
Best,
Geo
@fotowat
It looks like you are using 4K monitor...
This is the only suggestion for working with 4K/UHD displays as they are not currently supported.
1.Change the High DPI settings under compatibility settings. Right click on Workbench shortcut or start menu icon -> " Properties of workbench > Compatibility > Click on Override high DPI scaling "
2. Change the "Scaling performed by" option to "System(Enhanced)"
3. Could also try the option: Under Compatibility select "Disable display scaling on high DPI settings".
