s21 resonance
park0415park0415 Member Posts: 5
If you look at s21 in the figure below, there are several resonance components.
however, if the simulation is performed at 83.9GHz, the corresponding resonance component disappears.
Is it a matter of hfss simulation process? or setting problem?
  • pmunagapmunaga Posts: 140Forum Coordinator
    edited April 1
    Hi @park0415,
    Can you provide the details regarding the sweep type that you are using?
    Also, try solving at other marker frequencies and see if you can replicate the result.
    All the very best.
  • park0415park0415 Posts: 8Member
    @pmunaga
    First of all, thank you for replying.
    Are you talking about simulation sweep type?
    I use interpolating type when i simulate!
    And the resonance component did not disappear when proceeding at different frequencies.
    May I know whether the adaptive meshing converged?
    Try simulating with a lesser delta and see that the solution is converging.
    All the very best.
