Running batch files
I am using ANSYS Workbench 19.1, k-files and LS-DYNA to run impact simulations. I was using a batch file to run multiple simulations over night but the template file I used no longer works with the new license update.
Apparently, the "pr=aa_r_dy" line I used is no longer compatible.
What is the best way to run batch files now?
Also, could you inform on the best set up to run k files through Product Launcher please?
  • cxquancxquan Berkeley, CAPosts: 89Forum Coordinator
    Use "dyna" to replace "aa_r_dy" for "pr" in the batch file to see if it works.
    Typical setup in the 19.1 MAPDL Product Launcher to run LS-DYNA models (K files):
