Cylindrical Support in ANSYS ACP
in Structures
I am modeling a lug-like structure in static structural linked from ACP and wanted to use a cylindrical support for the hole. However, I was unable to select the geometry using either the shell or the solid model from ACP. When I click on the edge/face by itself, the entire circle is highlighted and in CAD, it was created on a flat plane. Is there something I am missing or a potential work around?
Hello @Sam1,
I don't fully understand your question. Do you mean that the geometric features that existed in ACP are not visible/selectable in static structural? Please check this https://forum.ansys.com/discussion/2831/geometry-areas-and-symmetries-transfer-after-acp and see if it helps.
Ishan.
Hi @1shan,
To clarify what I was asking, I meant that the edge of the circle/face created in either shell/solid model from ACP. is selectable in the following static structural and it is highlighted when I click on it. But when I go to try and apply a cylindrical support, it is not able to select it as a usable support.
Hello @Sam1,
You could try a work around. Create a cylindrical coordinate system at the center of the hole with proper orientation. Using node selection select all the circumferential nodes, RMB> named selection. Then insert a nodal orientation object, scope it to the named selection and the cylindrical coordinate system (this will orient the nodes in the new coordinate system). Next insert a nodal displacement, scope it to the named selection and then specify the DOFs (which will now be in the cylindrical coordinates).
Ishan.
