Workbench Output Parameters Issue
adityamulmuleadityamulmule Member Posts: 3
edited April 2 in Fluids
Sometimes, the output parameters from the Fluent output weird irrelevant values to the workbench (v19.2). For instance, if an output parameter has been set as 'area weighted average wall temperature' from the 'surface integral' reports, then its value collected in the workbench at the end of the simulation is quite different that had it been calculated via 'surface integrals' directly from the Fluent GUI.
Is there any reason this might be happening?
Many thanks
