can i use named expression for specific heat?
pc_singhpc_singh Member Posts: 9
I am not able to find the Named expression in the specific heat column.
  • YasserSelimaYasserSelima Posts: 944Member
    This is what I was wondering when you asked the other topic ... Use UDF , there is an example in the manual ... you need to plug your IF statements and formulas.
  • pc_singhpc_singh Posts: 39Member
    I have already written the UDF and compiled the code, but the results are not coming good.
    DEFINE_SPECIFIC_HEAT(CP, T, Tref, h, yi)
    real CP, Time;
    /*Setting up the magnetic field*/
    Time = CURRENT_TIME;
    for(;;)
         if(Time<=4.2)
           break;
         Time=Time-4.2;
             CP=0;
    if(Time<=0.1)
       CP=a+b*T+c*T*T+d*T*T*T+e*T*T*T*T;
      if(Time<=2.1 && Time>0.1)
         CP=f+g*T+h*T*T+i*T*T*T+j*T*T*T*T;
      if(Time>2.1 && Time<=2.2)
      if(Time>2.2)
        CP=k+l*T+h*T*T+m*T*T*T+n*T*T*T*T;
                    *h = CP*(T-Tref);
                return CP;
    Note: I mentioned here a general polynomial function.
       real  Time;
       /* enter the constants */
       real a = 0, b = 0, c = 0, d = 0, e = 0, f = 0, g = 0, h = 0, i = 0; j = 0, k = 0, l = 0, m = 0, n = 0;
       if(Time> 4.2) {
             Time=Time-4.2;
       if(Time<=0.1) {
       } else if (Time<=2.1 && Time>0.1) {
       } else  if(Time>2.1 && Time<=2.2) {
       } else {
       *h = CP*(T-Tref);
       return CP;
    enter the values of a, b, c ...
    Thank you. I'll do that.
    Actually, I didn't mention the values of constant here, I just took a general case.
