How to remove or correct the bad quality elements?
johnny02johnny02 Member Posts: 7
Hello all,
This is johnny here. I am having a problem with 6 bad elements whose skewness is about 0.91. so I need to remove or correct these elements.I even edited the geometry but again I am getting the same problem.
Thank you
  • peteroznewmanpeteroznewman Posts: 11,404Member
    edited April 4
    @johnny02
    Open the Geometry editor SpaceClaim and slice the solid up into six-sided pieces. Delete insignificant features of the geometry. Use the Share button on the Workbench tab to create shared topology for the meshing program.
    It looks like there is 4-fold rotational symmetry. Slice the body into 4 pieces and delete 3 of them so you only work on 1/4 to clean up the geometry. Then you can copy/rotate to get back the full domain when you are done cleaning up the geometry.
