How to get capture Debonding or CFRP rupture in Load-Displacement Curve? — Ansys Learning Forum
Mshrest2Mshrest2 Member Posts: 5
I am modeling RCC beam with NSM CFRP strengthening. Concrete is CPT215, Steel Rebar is Reinf264, and NSM epoxy and CFRP both are both Solid185. I am trying to simulate sudden dropdown in Load-displacement curve as shown in picture of experimental result. However my analysis goes on and on when I add load steps as shown in the picture. The sudden drop down corresponds either to the debonding (more specific concrete cover separation near epoxy-concrete interface) or rupture of CFRP.
I have attached the script material properties I have applied for CF
RP, epoxy and Contact elements. Con you suggest me how to get the drop down in the curve?
! Orthotropic Material Properties of CFRP NSM
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,5,,200000
MPDATA,EY,5,,14050
MPDATA,EZ,5,,14050
MPDATA,PRXY,5,,0.29
MPDATA,PRYZ,5,,0.29
MPDATA,PRXZ,5,,0.6
MPDATA,GXY,5,,5127.5
MPDATA,GYZ,5,,5127.5
MPDATA,GXZ,5,,4390.6
TB, FCLI, 5, 1,9,1
!TBDATA,1,Xnt,Xnc,Ynt,Ync,Znt,Znc
!TBDATA,7,Shear,Shear,Shear
TBDATA,1,2400,2250,69,350,69,350
TBDATA,7,87,87,87
!Material Model of Epoxy adhesive of NSM
MP,EX, 6, 3400
MP,NUXY, 6,0.37
TB,MISO,6,1,2,0
TBTEMP,0
TBPT,,0.0092,31.2
TBPT,,0.011,31.2
ESEL,S,MAT,,1 !Select elements of concrete
NSLE
NSEL,R,LOC,X,70,75
NSEL,R,LOC,Y,22
NSEL,R,LOC,Z,500,1600
CM,Target1,NODE
!Target 1 represents the nodes of concrete adjectent to top layer of epoxy/groove
ESEL,S,MAT,,6
NSLE
NSEL,R,LOC,X,70,75
NSEL,R,LOC,Y,22
CM,Conta1,NODE
!Conta 1 represents the nodes of top layer of epoxy in groove
!Cohesive Zone Modelling
TB,CZM,CZM_MMODEL,1,,CBDE
!TBDATA,1,snmax,Gcn,stmax,Gct,ita,bita
!TBDATA,7,alfa
TBDATA,1,4,0.043,9.65,1.44,1 E-8,0
TBDATA,7,2
ET,8,170 !Define Target element
ET,9,174 !Define Contact element
R,31, !Defined real constant for contact
KEYOPT,9,9,1 !Exclude both initial geometrical penetration or gap and offset
KEYOPT,9,12,3 !Bonded Contact: I am using bonded contact because when i use other contact type, the analysis terminates earlier with error in element formulation
TYPE,9
REAL,31
CMSEL,S,CONTA1
ESLN,S
ESURF          ! FORMING CONTACT ELEMENTS
ALLSEL,ALL
TYPE,8
REAL,31
CMSEL,S,TARGET1
ESLN,S
ESEL,R,MAT,,1 !elements of concrete, elements of discrete steel reinforcement was unnecessary selected and hence this command used
ESURF          ! FORMING TARGET ELEMENTS
ALLSEL,ALL
!Similarly Contact pair with same CZM material and different element no. and real constant was defined at left side of cross section of the groove
!Similarly Contact pair with same CZM material and different element no. and real constant was defined at common cross section of concrete and epoxy (beginning of groove in longitudinal direction)
!NOTE: The epoxy of groove is in contact with concrete in 5 sides (top, left, right,front and back, free only at the bottom). Only quarter of the beam is modeled and hence contact is defined in only three directions
!Script for load displacement curve
n_uy=NODE(75,0,1600) ! node at mid span where displacement is read
ALLSEL,ALL
CMSEL,S,A1 ! A1 represents the nodes at which the displacement is applied as load
*GET, n_min, NODE, 0, NUM, MIN, ,
*GET, n_max, NODE, 0, NUM, MAX, ,
*GET, n_count, NODE, 0, COUNT, , ,
finish
/POST1
SET,LAST
finish
/POST26
NUMVAR, 200
ii=n_min
*do,i,1,n_count,1
rforce,2, ii,F,Y,FY
!ADD, 3, 3, 2,,FYT,,,,-0.002, !for half model
ADD, 3, 3, 2,,FYT,,,,-0.004, !for quarter model
!ii=NDNEXT(ii)
*GET, iii, NODE, ii, NXTH, , ,
ii=iii
*ENDDO
NSOL,4,n_uy,U,Y,UY
ABS,4,4,,,UY
/AXlab,X,displacement [mm]
/AXlab,Y,force [kN]
XVAR, 4
PLVAR, 3
