how to solve ''The mesh doesn't contain any shell elements''
''The mesh doesn't contain any shell elements this may be because the model is not compatible with section data provided''
I saw the other discussions regarding this problem however they had the problem while trying to export files from ACP to structure static or some other systems while for me it appeared right after I finished the meshing, what should I do?
