Problem in installing ANSYS Student
I have problem in installing ANSYS Student. I checked install.err file, but I don't know how to solve it. This is error message I got.
###### Error #######
   Error executing configuration script 'C:\Users\User\AppData\Local\Temp\ans_install_tmp14812\config\AnsConfigCommon.tcl'
   '"C:\Users\User\AppData\Local\Temp\ans_install_tmp14812\tcl\bin\winx64\tclsh.exe" "C:\Users\User\AppData\Local\Temp\ans_install_tmp14812\config\AnsConfigCommon.tcl"  -installdir "C:\Program Files\ANSYS Inc\ANSYS Student" -rev 211 -dotrev 2021 R1 -scripttosource "C:\Users\User\AppData\Local\Temp\ans_install_tmp14812\config\ConfigCommon.tcl" -sourcedir "C:\Users\User\AppData\Local\Temp\ans_install_tmp14812" -os_lang ko -install ' terminated after 1 attempts with the following error(s):
       Unknown error
   Exit Code: 1
   couldn't read file "C:\Users\User\AppData\Local\Temp\ans_install_tmp14812\config\AnsConfigCommon.tcl": no such file or directory
I got multiple errors similar with this for other tcl files such as AnsConfigTG.tcl, AnsConfigLicClient.tcl, AnsConfigACP.tlc, etc.
How can I solve this?
  • Geo KarnosGeo Karnos Posts: 161Ansys Employee
    LeeHansol
    Make sure you extract the files from the download before running the setup.exe.
    Also, When running setup.exe, right click on it and choose:
    more->run as administrator
    Please let me know if this helps!
    Geo
  • LeeHansolLeeHansol Posts: 2Member
    I used run as administrator, but it didn't helped the problem.
    Should I extract the every WINX64.7z files in the folders? I think there's too many WINX64 files in this, and I didn't need to extract every files when I installed ANSYS in another computer before.
    LeeHansol,
    No, just extract the download package into a temp directory, like: c:\ANSYSDownload
    One other thought would be to check for virus scanning software. Try disabling it, then install.
