Issue Running Ansys ls-dyna
amq7yamq7y Member Posts: 1
Hi, I am trying to use ansys LS-DYNA in linux OS and I get the following error message, I have done the following steps to get to this point,
1. Installed Ansys with Lsdyna feature
2. Exported the license information, I am able to run Ansys Fluent with the same license information.
3. I am not able to see the ls-dyna extension from the extension manager after launching the workbench
4. We do have license feature(aa_r_dy) which should allow us to use Ansys ls-dyna
5. I get the error message as shown when launching the lsdyna executable
Do I need an separate license for Ansys ls-dyna? or am I missing something here?
Asif.
  • cxquancxquan Berkeley, CAPosts: 92Forum Coordinator
    ANSYS Installation files include LS-DYNA Installation files.
    Are the LS-DYNA executables in your computer coming from ANSYS Installation files?
    When LS-DYNA starts, can you check the output to see if it includes the ANSYS license information? See attached picture below.
  • amq7yamq7y Posts: 4Member
    This is what the output I have
    Yes, the ls dyna executable comes from the installation location.
    Asif.
    Thanks. Can you check the Environmental Variables in the Linux machine to see if the LS-DYNA license manager is pointing to ANSYS?
    If not, set the following environmental variable:
    LSTC_LICENSE=ANSYS
    I did not have the variable LSTC_LICENSE=ANSYS before, after your response, I have add LSTC_LICENSE variable along with previous variables as follows,
    export ANSYSLI_SERVERS=2325@server.col.missouri.edu
    export ANSYSLMD_LICENSE_FILE=27003@server.col.missouri.edu
    export LSTC_LICENSE=ANSYS
    and then I run /cluster/software/ansys/ansys-2021R1/v211/ansys/bin/lsdyna
    I still get the same error,
    Asif.
    Hello cxquan,
    Is the error message related to licenses or something else?
    Asif.
