How to access model properties in script file editor
lStolzlStolz Member Posts: 3
edited April 22 in Photonics
I have my simulation defined by property variables in the model object. Now I want to access (and change) these properties with a script. However I can not select the model object with select("model"). So how do I do that?
Cheers
Levin
  • greg_baethgegreg_baethge Posts: 121Ansys Employee
    Accepted Answer
    Hi @lStolz,
    Thanks for posting your question. The "model" object is a bit particular, to reference it in select or in setnamed, you need to use "::model". For example:
    setnamed("::model", "prop", value);
    I hope this will help!
