An inquiry regarding an error
amoraamora Member Posts: 10
I am trying to run a script but I got an error ''Error: D:/Design/file.lsf line 78: syntax error'' and I am sure that there is no error. Can you have a look please and let me know where's the error?
I have attached a text file with my script. I got the error at line 78. Just try to copy and paste the text file into LSF and see where's the error please.
  • kjohnsonkjohnson Posts: 204Ansys Employee
    Hello @amora ,
    Ansys staff can't download files from the ALF, can you please copy and paste the script into the text of a post? Because this is a syntax error, I think only a few lines (for example lines 75-80) should be needed to see what the problem is.
  • amoraamora Posts: 24Member
    Hello Kjohnson,
    Thanks for your reply. Here is a copy of the script:
    deleteall;
    #Adding the FDTD solver region to the simulation
    xs=300e-9; #radius of holes or circles
    ys=200e-9;
    p=ys+90e-9; #period of array
    #p=332e-9;
    t1=200e-9;
    t2=5e-9;
    #t=50e-9; #thickness of film and holes
    addfdtd;
    set("dimension",2);
    set("x",0);
    set("x span",p);
    set("y",0);
    set("y span",p);
    set("z min",-9.2e-6);
    set("z max", 10.5e-6);
    set("allow symmetry on all boundaries", 1);
    set ("y min BC","Anti-Symmetric");
    set ("y max BC","Anti-Symmetric");
    set ("x min BC","symmetric");
    set ("x max BC","symmetric");
    set ("pml profile",[3]);
    set ("pml layers",[12]);
    set("simulation time",13000e-15);
    set("auto shutoff min",10e-6);
    set("mesh accuracy",3);
    #Setting the simulation boundaries
    addmesh;
    set("name","mesh");
    set("x",0);
    set("x span",xs);
    set("y",0);
    set("y span",ys);
    set("z min",t1);
    set("z max",t2+10e-9);
    set("override x mesh",1);
    set("override y mesh",1);
    set("override z mesh",1);
    set("set maximum mesh step",1);
    set("dx",14e-9);
    set("dy",14e-9);
    set("dz",14e-9);
    #Adding the structure
    addrect;
    set("name","Substrate");
    set("material","CaF3");
    set("x",0);
    set("x span",8e-6);
    set("y",0);
    set("y span",8e-6);
    set("z min",-16.5e-6);
    set("z max",0);
    #Adding Ti
    #addrect;
    addrect;
    set("name","Ti layer");
    set("x",0);
    set("x span",8e-6);
    set("y",0);
    set("y span",8e-6);
    set("z min",0);
    set("z max",t1);
    set("material","Ti (Titanium) - Palik");
    #Adding rectangles
    z_span=0.1e-6;
    nx=3; ny=3;
    ax=0.4e-6;
    ay=0.4e-6;
    n_rows = ny-1; #no. of periods in x direction
    n_cols = nx-1; #no. of periods in y direction
    even_flag = 0;
    for(i=-n_rows/2:n_rows/2) {
    for(j=-n_cols/2:n_cols/2) {
    addcustom;
    set("create 3D object by","extrusion");
    set("equation 1","1-abs(x)"); # abs(y) = 1-abs(x)
    set("x span",xs);
    set("y span",ys);
    set("x",(j)*p);
    set("y",(i)*p);
    set("z min",t1);
    set("z max",t2);
    set("material","Ge (Germanium) - Palik");
    #Adding the source
    addplane;
    set('injection axis','z');
    set('direction','backward');
    set('x min',-1e-6);
    set('x max', 1e-6);
    set('y min',-1e-6);
    set('y max',1e-6);
    set('z',5e-6);
    set('wavelength start',3e-6);
    set('wavelength stop',7e-6);
    set('polarization angle',90);
    Hello @amora ,
    Thank you for providing the script. I'm not allowed to run this script myself unfortunately, and the formatting on the forum may have changed the line spacing so I'm not sure which is line 78. Can you please let me know which line is causing the error? Is it this one: 'set("equation 1","1-abs(x)"); # abs(y) = 1-abs(x)'?
