ANSYS ICEM 16.2
lucaCUlucaCU Member Posts: 1
Good Morning,
I am using ANSYS 16.2 for backward compatibility with other tools. However, I recentely figured out that the blocking tab wihtin the file menu disappeared. This means that for example I cannot anymore import .tin file and then import blk file later on. I attach an image that shows the missing blocking tab in ANSYS 16.2 which is still available for instance in ANSYS 16.2.
I also tried to eanble the option within Settings> Product but it did not work either.
Do you have any advice on that?
Thank you
Luca
