I cannot create a new cross-section with Design Modeler.
I designed the drawing with Inventor, saved it as a file(.stp), and imported it into Geometry.
I need to look at the cross section to insert pressure inside the object. However, using "new cross-section" with Design Modeler will cause problems with the software.
The message "AnsysWBU.exe encountered a problem. A diagnostic file has been written: C\User\username\AppData\Local\Temp\AnsysWBDumpFile.dmp" will be displayed as shown in the image.
For any object, the problem arises when I try to look at a cross section.
The following is about my environment.
  • software : Ansys Student 2021 R1
  • CPU : Ryzen 9 4900HS with Radeon Graphics
  • GPU : RTX 2060 with Max-Q Design
If you know how to solve this problem, I would appreciate your advice.
