Dipole source base amplitude
EricJzzzEricJzzz Member Posts: 1
I am working on an FDTD simulation with a dipole source. The amplitude of diple is automatically multiplied by the base amplitude of order 1e-24. Is there any way to change the base amplitude to 1? If not, can we get the value of base amplitude with script (maybe with "getdata" command) so I can normalize the frequency domain field manually?
Eric
  • gsungsun Posts: 323Ansys Employee
    Accepted Answer
    You can use script to get the original data, eg,
    getnamed("source","base amplitude");
    you can use
    ?getnamed("source");
    from the prompt to get a list of all the parameters you can get from the source settings.
    You can also use
    ?getresult("source");
    to get simulated data from the source.
    Please try and let me know if you have questions.
