Longitudinal MOKE signals in the FDTD solver
MansoorASMansoorAS Member Posts: 2
I am trying to access a thread on Lumerical knowledge exchange but it was removed. I wonder if anyone can help me to see if there was any solution to the problem
Here is the link for the thread.
https://kx.lumerical.com/t/longitudinal-moke/72037
  • kjohnsonkjohnson Posts: 219Ansys Employee
    Accepted Answer
    Hello @MansoorAS ,
    The suggested solution to simulating a longitudinal MOKE surface was to take the example from this link (with polar MOKE orientation) and change the orientation of the source/surface instead of trying to change the MOKE orientation:
    For example, a plane wave source propagating in the y direction with a surface oriented in the x-z plane using the MOKE material from that example would have longitudinal orientation. This is simpler than trying to come up with a new grid attribute matrix, which can be complicated. However the user didn't reply, so I'm not sure if this worked.
    Let me know if that answers your question.
