Error in Sweep
Anish_MondalAnish_Mondal Member Posts: 7
The following error is shown after the sweep is completed. Looking for help regarding both warnings.
  • gsungsun Posts: 1,152Ansys Employee
    Accepted Answer
    The error message says that the E field changes its dimension during the sweep. I guess you are sweeping the geometry, so the mesh changes and consequently the E changes its matrix dimension.
    To remedy, please add an override region to cover the possible region of a geometry change so to fix the mesh, and thus the E field matrix will not change during the sweep.
    BTW:Please make sure E field is necessary for the sweep.
