Error with lumerical license activation.
aadityaaaditya Member Posts: 1
I am a Ph.D. student at USC and want to use Lumerical FDTD for simulations. We have purchased an ANSYS Academic Lumerical Research (1 task). The High Performance Computing has installed the license manager and the software for our use on USC supercomputer cluster, but we are not able to run simulations . On submitting a job I get the following error:
Due to MODULEPATH changes, the following have been reloaded:
 1) pmix/3.1.3
a02-26.hpc.usc.edu(process 0): Error: Unable to obtain a node locked or floating license. Either activate a node locked license or enter the address for your floating license server. Please see the <a href=https://kb.lumerical.com/redirect/fwd3.html>Troubleshooting guide</a> for help resolving this issue.<p><b>Floating error: -97</b> The desired vendor daemon is down.
 Check the lmgrd log file, or try lmreread.
Feature:    FDTD_Solutions_engine
Vendor:Host:  hpc-dns
License path: 1055@hpc-dns:
FlexNet Licensing error:-97,121. </p>
Would you like to reconfigure your license settings?, Response: No
[a02-26:63679:0:63679] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x90)
==== backtrace (tid: 63679) ====
 0 0x00000000000532a3 ucs_debug_print_backtrace() /build/csul/spack-stage-ucx-1.8.0-o6fhjkqszinevp3soi5szm76tkw3tjl2/spack-src/src/ucs/debug/debug.c:625
 1 0x00000000023ecfc9 std::vector<unsigned long, std::allocator<unsigned long> >::push_back() ???:0
 2 0x0000000001a7d261 std::_Vector_base<std::string, std::allocator<std::string> >::_Vector_impl::~_Vector_impl() ???:0
 3 0x000000000050ddc5 ???() /spack/apps/lumerical/2021-R1.3/bin/fdtd-engine-ompi-lcl:0
 4 0x0000000000022555 __libc_start_main() ???:0
 5 0x0000000000500ff5 ???() /spack/apps/lumerical/2021-R1.3/bin/fdtd-engine-ompi-lcl:0
srun: error: a02-26: task 0: Segmentation fault
slurmstepd: error: a02-26 [0] pmixp_client_v2.c:210 [_errhandler] mpi/pmix: ERROR: Error handler invoked: status = -25: Interrupted system call (4)
srun: Job step aborted: Waiting up to 32 seconds for job step to finish.
slurmstepd: error: *** STEP 4314389.0 ON a02-26 CANCELLED AT 2021-05-04T15:31:23 ***
srun: error: a02-26: tasks 1-7: Killed
The people at USC-HPC have said that the license server is up and running. Here is what they have sent:
Flexible License Manager status on Tue 5/4/2021 15:44
License server status: 1055@hpc-dns
  License file(s) on hpc-dns: /var/local/ansys_inc/shared_files/licensing/license_files/ansyslmd.lic:
  hpc-dns: license server UP (MASTER) v11.17.2
Vendor daemon status (on hpc-dns):
 ansyslmd: UP v11.17.2
Feature usage info:
Users of lum_charge_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_cml_compiler: (Total of 1 license issued; Total of 0 licenses in use)
Users of lum_dgtd_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_eme_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_fde_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_fdtd_gui: (Total of 1 license issued; Total of 0 licenses in use)
Users of lum_fdtd_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_feem_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_heat_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_interconnect_gui: (Total of 1 license issued; Total of 0 licenses in use)
Users of lum_interconnect_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_mode_gui: (Total of 1 license issued; Total of 0 licenses in use)
Users of lum_mqw_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_multiphysics_gui: (Total of 1 license issued; Total of 0 licenses in use)
Users of lum_stack_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_varfdtd_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Users of lum_veriloga_solve: (Total of 4 licenses issued; Total of 0 licenses in use)
Can you please help us resolve this error?
With warm regards,
Anikeya Aditya
  • mmadoremmadore Posts: 849Ansys Employee
    @aaditya Please make sure the port for the ansyslmd daemon is open on the license server firewall. Starting with 2021R1 the applications must communicate through ansyslmd and lmgrd.
    You can set ansyslmd to a static port by adding it in the license file on the VENDOR line.
    For example:
    VENDOR ansyslmd PORT=1056
    From the client machine where you are trying to run Lumerical, please try to telnet to the license server on the 2 licensing ports to confirm connectivity. To test the access, you can use one of these options, please try for the lmgrd port and ansyslmd port, modify the command to replace "192.168.0.1" with the license server hostname.
    Telnet 192.168.0.1 1055
    nc -v -z -w2 192.168.0.1 1055
    (echo >/dev/tcp/192.168.0.1/1055) &>/dev/null && echo "Open 1055" || echo "Close 1055"
  • LitoLito Posts: 54Ansys Employee
    edited May 5
    @aaditya
    Just to add, your error message indicates that you are trying to checkout a license feature that is not on your license server,
    You will need Lumerical/FDTD version 2021 R1 to be able to checkout the license from your Ansys license server, 1055@hpc-dns. And configure Lumerical to obtain the license from Ansys (standard) LM.
    If you do not have GUI access to the cluster, set the license configuration as shown in this article. Where domain=2 for the Ansys (Standard) license server.
    Best,
    Lito
