Ask: How to draw an arc with a right-angled trapezoid in cross section through code?
phillphill Member Posts: 3
Currently through addpoly; draw the arc structure. Below is the code and graphics
Now the requirements are: the same is arc but I want to change the cross section from rectangular to right-angled trapezoid. How to modify the code? The cross section is shown in the figure below
The slope of the hypotenuse of the trapezoid is a variable that is adjusted by the angle。
thank you!!!
  • greg_baethgegreg_baethge Posts: 93Ansys Employee
    Accepted Answer
    I definitely agree it's not simple. The limitation of addpoly is it can only create a shape that is extruded in the z direction, so it can't have any angle in the vertical walls. I had a bit of time, so I wrote this script:
    ## Definition of the vertices coordinates
    z_bot = matrix(res);
    z_top = z_bot + thickness;
    x1_top = rad1 * cos(t1);
    y1_top = rad1 * sin(t1);
    z1_top = z_top;
    x2_top = rad2 * cos(t1);
    y2_top = rad2 * sin(t1);
    z2_top = z_top;
    x2_bot = rad2 * cos(t1);
    y2_bot = rad2 * sin(t1);
    z2_bot = z_bot;
    x1_bot = (rad1 - thickness*tan(thetarad)) * cos(t1);
    y1_bot = (rad1 - thickness*tan(thetarad)) * sin(t1);
    z1_bot = z_bot;
    x = matrix(4*res);
    y = matrix(4*res);
    z = matrix(4*res);
    x(1:res) = x1_top; # top R1
    y(1:res) = y1_top;
    z(1:res) = z1_top;
    x(res+1:2*res) = x2_top; # top R2
    y(res+1:2*res) = y2_top;
    z(res+1:2*res) = z2_top;
    x(2*res+1:3*res) = x2_bot; # bot R2
    y(2*res+1:3*res) = y2_bot;
    z(2*res+1:3*res) = z2_bot;
    x(3*res+1:4*res) = x1_bot; # bot R1-angle
    y(3*res+1:4*res) = y1_bot;
    z(3*res+1:4*res) = z1_bot;
    vtx = [x,y,z];
    ## Definition of the facets
    fct = cell((res-1)*4+2);
    for(i=1:length(fct)){
    fct{i} = cell(1);
    fct{1}{1} = [1, res+1, 2*res+1, 3*res+1];
    fct{2}{1} = [res, 4*res, 3*res, 2*res];
    for(i=1:res-1){
    j = i+2;
    fct{j}{1} = [3*res+i, 3*res+i+1, i+1, i];
    fct{j+res-1}{1} = [i, i+1, res+1+i, res+i];
    fct{j+2*(res-1)}{1} = [2*res+i, res+i, res+i+1, 2*res+i+1];
    fct{j+3*(res-1)}{1} = [3*res+i, 2*res+i, 2*res+i+1, 3*res+i+1];
    addplanarsolid(vtx, fct);
    Where thetarad is the angle of wall in radian, rad1 and rad2 the 2 radii (taken from the top surface). This should create a object like this:
    Let me know if you have any question
    Hi @phill,
    Thank you for posting your question. I think you should be able to create such structure using a planar solid object. It's a bit tricky, as you have to:
    1. divide the structure in n facets each made of 4 vertices.
    2. define all the vertices needed to define the facets (there should be 4*res vertices, that can be defined in a similar way as in your current code)
    3. connect the vertices to create the facets (there should be (res-1)*4+2 facets to cover front, back, top, bottom and sides)
    the latter is usually the painful part! We have this example that could be helpful:
    Let me know if you run into any issue.
  • phillphill Posts: 7Member
    thank you for your reply. The solution you gave seems to be a bit difficult. If you can solve this problem through “addpoly”, thank you.
    Thank you for taking the time to help, the problem has been resolved. I may need your help if I face difficulties.
