Regarding Boundary setting on FDTD using python API
felix0616felix0616 Member Posts: 2
Currently, I am having difficulties on setting the PML boundaries respectively for each end, as PML settings is given as a table, while using tuples only allow one variable and one input.
Is there any way to alter settings, say y max bc PML conditions, respectively using python API?
Thank you
    Hi, Felix,
    Did you write your own code in the first screenshot? Do you want to set the PML all the same, or you want to specify it for each direction? It seems the the x,y PML BCs have been set correctly. Could you please try to modify the script as you expect, and let us know what the error message it shows? you can find all the parameters for script settings by type ?setnamed("FDTD"), here is the list:
     ?setnamed("FDTD");
    allow grading in x
    allow grading in y
    allow grading in z
    allow symmetry on all boundaries
    always use complex fields
    angle phi
    angle theta
    auto shutoff max
    auto shutoff min
    background material
    bfast alpha
    bfast dt multiplier
    bloch units
    checkpoint at shutoff
    checkpoint during simulation
    checkpoint period
    conformal meshing refinement
    define x mesh by
    define y mesh by
    define z mesh by
    dimension
    direction
    down sample time
    dt
    dt stability factor
    dx
    dy
    dz
    enabled
    extend structure through pml
    force symmetric x mesh
    force symmetric y mesh
    force symmetric z mesh
    global monitor custom frequency samples
    global monitor frequency center
    global monitor frequency points
    global monitor frequency span
    global monitor maximum frequency
    global monitor maximum wavelength
    global monitor minimum frequency
    global monitor minimum wavelength
    global monitor sample spacing
    global monitor use source limits
    global monitor use wavelength spacing
    global monitor wavelength center
    global monitor wavelength span
    global source bandwidth
    global source center frequency
    global source center wavelength
    global source eliminate discontinuities
    global source frequency
    global source frequency span
    global source frequency start
    global source frequency stop
    global source offset
    global source optimize for short pulse
    global source pulse type
    global source pulselength
    global source set frequency
    global source set time domain
    global source set wavelength
    global source wavelength span
    global source wavelength start
    global source wavelength stop
    grading factor
    index
    injection axis
    kx
    ky
    kz
    max source time signal length
    mesh accuracy
    mesh cells per wavelength
    mesh cells x
    mesh cells y
    mesh cells z
    mesh frequency max
    mesh frequency min
    mesh refinement
    mesh type
    mesh wavelength max
    mesh wavelength min
    meshing refinement
    meshing tolerance
    min mesh step
    name
    nx
    ny
    nz
    override simulation bandwidth for mesh generation
    param1
    param2
    pml alpha
    pml alpha polynomial
    pml kappa
    pml layers
    pml max layers
    pml min layers
    pml polynomial
    pml profile
    pml sigma
    pml type
    same settings on all boundaries
    set based on source angle
    set process grid
    set simulation bandwidth
    simulation frequency max
    simulation frequency min
    simulation temperature
    simulation time
    simulation wavelength max
    simulation wavelength min
    snap pec to yee cell boundary
    source index
    type
    use auto shutoff
    use bfast fdtd
    use divergence checking
    use early shutoff
    use legacy conformal interface detection
    use relative coordinates
    x
    x max
    x max bc
    x min
    x min bc
    x span
    y
    y max
    y max bc
    y min
    y min bc
    y span
    z
    z max
    z max bc
    z min
    z min bc
    z span
    You can set those parameters using the code in the 1st screen image. You can also refer this link https://support.lumerical.com/hc/en-us/articles/360037824513-Python-API-overview and the related examples. The examples have python files that you can borrow for your use.
