What can I do with the Synthesizer Tool in Granta EduPack?
NickSNickS Member Posts: 1
edited June 2021 in Materials
With the Synthesizer tool you can access in-built models that will allow to:
·       Predict Properties of the following Hybrid Materials: composites, sandwich panels, multi-layer materials, dual material lattices and cellular structures.
·       Perform design of battery modules and packs.
·       Estimate Cost of a part made with different materials and manufacturing routes.
·       Create your own model to perform additional calculations on existing records.
How do I access the Synthesizer Tool?
You can access the Synthesizer through the top toolbar menu. This tool is only available through the advanced level 3 databases.
How do I create a mode in the synthesizer?
You can access the Model Write’s Guide through a link at the bottom of the Synthesizer Tool.
Can I use the user-created or Synthesizer records in the Eco-Audit?
In EduPack 2021R2 you can only use records from the material universe database in the Eco-Audit tool.
Can I use the user-created records in the Synthesizer?
In EduPack 2021R2 you can only use records from the material universe database in the Synthesizer tool.
Can I export Synthesizer-created records into Ansys Mechanical?
In EduPack 2021R2 you can export both standard and Synthesizer records to a selection of CAD/CAE software as shown in the picture below.
