how to Analyze and simulate 4-rotor UAV (simulation results)
Hello all,
I'm working with ANSYS 18.2 version,
I'm doing a 3d simulation of flow field for a 4-rotor UAV.
I have a transient state case.
The steps I did:
1.used (realizable.k-e.scalable wall fn)
2.turn on mesh motion for each blade
3.used 2 pressure outlet
4.time step size :0.01
The lift values obtained for each rotor are small and negative and The flow lines are not symmetric
  please help me:
1. How do I know that my simulation is correct?
2. How to calculate the total lift and thrust values
Thank you
With regards
fa-ri
  • seeta guntiseeta gunti Member
    edited October 2018
    Hello Fari,
    Regarding calculation of lift and drag, we have a tutorial in the youtube. Please watch the video as given below.
    Make sure that you gave the correct input values for rotor axis direction, axis center and rotational speed ( RPM/ RPS).
    Seeta
  • fa-rifa-ri Member
    edited October 2018
    Hello Seeta
    Thank you for your response.
    here is my data
    Forces - Direction Vector (0 1 0)
                                     Forces (n)        Coefficients
    Zone                        Pressure              Viscous                Total                  Pressure                Viscous                     Total
    prop_1                    0.017310849        -9.460496e-05      0.017216244     0.028262611         -0.00015445708        0.028108154
    Net                          0.017310849        -9.460496e-05      0.017216244     0.028262611        -0.00015445708         0.028108154
    But the result is not correct by comparing values with experimental values.
    and about the steamlinesThere is a lot of Wake streams.
    how can i khow that my simulation is correct?
    edited October 2018
    Hello Fari,
    Please make sure that you give the right boundary conditions and right axis rotation and center of axis of the rotor. Sometimes, the speed will be given wrong. Please check you use the right units.
    Refer some tutorials on mesh motion with some rotational speed in Youtube to check your settings.
  • KremellaKremella Forum Coordinator
    edited October 2018
    Just to add to Seeta's comments, if you are seeing discrepancies only in the coefficients (and your forces seem correct), you might want to take a look at your reference values).
    Best Regards,
  • fa-rifa-ri Member
    edited October 2018
    Hello Karthik,
    I've checked the values (both) and the amount is too much lower than reality
    With regards
    fa-ri
