Microfluidic particle flow
TonybruceTonybruce Member Posts: 1
I need to find out how ferrofluid flowing through a pipe react to a magnetic field. Please help me with this problem how to do it.
  • RobRob UKPosts: 11,770Forum Coordinator
    You'll need to determine the electric field and then use a UDF to add sources into the fluid to make it move: which potentially will alter the field. Start with the tutorials and then read the UDF manual. Finally scope out the problem very carefully to apply what you've learnt to build the model.
