different shape of structured adding in one structural group
InfiniteInfinite Member Posts: 9
Hello, How to add different types of structures in the same structural group by script command, as I am seeing it only add the 1st type of structure not all other type.
  • kjohnsonkjohnson Posts: 204Ansys Employee
    Hello @Infinite ,
    The addtogroup script command should work for any geometry object, for example:
    addrect;
    set("name","substrate");
    select("substrate");
    addtogroup("::model::G1::G2"); #this object is added to the group "G2"
    addring;
    set("name","ring");
    select("ring");
    Does this answer your question?
  • InfiniteInfinite Posts: 34Member
    Hello Kjohnson,
    Thank you for the answer.
    At line to of the script, it is showing syntax error. I am typing this on the script of another structure group. So I assume this another structure group is 'G2' and 'G1' some object already present under my model right?
    So is there any properties that I need to add first on the G2 property option?
    Also if I want to rotate one of the structure then how to set rotation?
    Thank you
    Hi @Infinite ,
    This script was designed to be run from an *.lsf file, but it shouldn't be showing a syntax error if it's run from a structure group setup script. If the structure groups in the "addtogroup" command don't exist they should be created, for example:
    You can rotate structure groups or individual objects by changing the settings in the "Rotations" tab of the edit dialog window, or by using the "set" command:
