Dynamic Mesh using Profile for Rigid Body
I´m trying to do this tutorial: Howewer I want to use a Profile instead of a UDF.
I have made the geometry and the meshing successfully.
Boundary Conditions: - Inlet: 0 Pa (Type Pressure)
                                   - Piston (Type Wall) and Settings by Default
Below you can see the Profile file. ".." is used in order to not writing all the components.
((piston1 transient 101 0)
(time
0
0,02
0,04
0,08 ..
1,98
2
(u
0
0,050636564
0,046777181
-0,004418245
-0,042826439..
0,008827861
0,058051301
The problem is that my velocity in all directions is 0.
Maxime
    edited October 2018
    Please check if you are running the case transient. Moreover check chapter 10.6.9.8. Solid-Body Kinematics to have the right format and specifications for your profile. Afterwards save case file and preview the mesh motion for verification purposes (Please save case file before doing that). For the profile use the specifications mentioned in the documentation (naming is important v_x, v_y, v_z,...).
  • Max4Max4 Member
    edited November 2018
    Thank your for your reponse. It has worked!
    Maxime
