Crash with Exit code 1073741819
Dear all,
after finishing the mode setup with polyfow, when I try to start the solution immediately an error message occures:
Refreshing of the solution component failed.
(Crash) Exit Code: -1073741819
Searching for this error, I found some hints that it might be a problem of memory allocation. has anyone an idea what to do now?
This happens with a small 2D model with a medium-fine mesh.
Thank you very much for a hint!
Hello Jasmina,
Could you please check your Task Manager while trying the solution to see if it hits the memory limit?
Usually 2D models wouldn't exceed the memory limit unless you tend to use extremely fine elements.
Thank you very much!
In the meantime I deleted the projekt and restarted with different settings. It works not - but I don't know what was crucial for the error ellimination..
When this Error occures again, I check the task manager. But I am sure it didn't hit the limit because the calculation was not expensive compared to the following projects.
best regards
