How to join two bodies to make assembly in design modeller
i have two geometry from that i have to make an assembly, it is easier to do in solidworks by defining mate, but i want to know how to use something like that in design modeller.
    edited October 2018
    There is no direct command like mate in DM.
    You can use Create --> Body operations  and move your body at particular location.
    You can find more details of these commands in help manual. You can also see following video.
    Keyur
    edited October 2018
    Did it help you? Are you able to assembly your geometry?
    Also, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
    Keyur
  • vkumarsingh388@gmail.com[email protected] IndiaMember
    edited October 2018
    it means i have to import all geomtries into DM and then i have to place them correctly and have to define contacts in ANSYS Mechanical, is it?
    edited October 2018
    Yes, its correct.
    Keyur
    edited October 2018
    Keyur
